The Daily CLAD
Community Browser
Rif.: CLAD2017 - Fundamentals - Waveform Charts
SercoSteveB
Which of the following Waveform Charts contains data generated by the VI?
Comments
crossrulz
Knight of NI
Chart, by default, transposes the array.  So C.
GCentral
maccapple
C. Could have been D in case waveform chart replaced with waveform Graph
A.Bernau
Not A and not B (array size 5x5 and 4x4).
I would say C and D (array size 4x5 and 5x4).
One of them transposed.
wayrider
As Chart Transpose the Array. Answer is D
ZacharyHuang
c)
Jiaming218
WHY?
Sangameshsh
in case of graph 4*5
but since its chart defaultly transposes array so its 5*4 (5 diff siganls with 4 values each) so its C
Ananth9
C
CA-Pioneer
Answer is C. The Chart show the 4 signals in order to time 0,1,2,3 -> line 1, then repeat for loop 5 to generate 5 lines. It is different with Graph.
nanithabe
it has 4 random variable, so in chart 4 line should be there. then N=5, so its from 1-5 not 0-5. so 5 points should be there. then the answer is D
